scottg918514
- Joined
- Sep 13, 2010
- Posts
- 341
- Reaction score
- 5
I encountered my first real maintenance hurdle today. I've changed all the fluids, fixed axle seals, replaced shocks, replace window regulators, etc... But, today I started to change my transmission fluid, drop the pan and change filter.
All was going pretty good until I realized I couldn't get the pan down because the shift cable bracket was in the way. I had already disconnected the shift cable and put it out of the way, but didn't remove the bracket.
Stupid thing has a T-40 Torx bolt on top, screwed down towards the ground. Impossible to get to, I can barely touch it, let alone turn a wrench on it.
Pissed me off, horrible design. I've heard of others just bending it out of the way. But, I can't get enough torque or room to bend it either. It is right next to the drive shaft, so, again no room to maneuver.
I did, at least, drain out 3 qts. and replaced, and what I drained looked good. I guess I'll take it in to a tranny shop, filter and gasket in hand and surrender.
Unless, anyone can tell me a trick to get to that bolt. I figure I just need to get to the one by the actual cable ring, and then pivot the bracket out of the way.
