Fuel Blitz Wheels with Factory Tires?
Jandy
Question for all you tire/wheel experts: I just got a 2024 Suburban Z71 with the 275/60R20 Goodyear Wrangler setup. I want to swap the wheels and get the Fuel Blitz gloss black wheels. With the tires being brand new, I figured I would just run them on the new wheels. Will this be an issue, or will the stock tires mount up on the Fuel Blitz 20x9 wheels just fine?
Also, I'd like to get a slightly wider stance for a little more aggressive look, what backspacing should I get in order to have the tires roughly an inch wider than the stock wheels?
Thanks!
Big Mama
Virginia
If your stock wheels are 9” then the tires are fine. There is a wheel size calculator on line that can help with offset. My guess is around 10-15 should do it.
djnice
Stock offset is around 28 mm, you can google or look at the back of your wheels. 1" = 25.4 mm. So a +1 offset will move them out about 1.1". I think you can only get the blitz in 16 or 1. 16 offset is only going to move them about 12mm or 1/2".
Here you can see what 1 offset looks like with slightly wider tires.
BigBodyBurban
