Fuel gauge reads "E" at all times
Phantom240
Phantom240
Theoretically, if I found a cluster that DIDN'T do these shenanigans, would I be able to just swap the bad parts? I know the PCM was worked into the mix for my particular model year, does that make a difference?
_Dylan_
STAY FROSTY
read my mind. :)
I just checked my cluster, the gauge is bolted in with 2 T9 torx screws.
I will likely be swapping the good motor from my 97 into this 99 cluster.
To remove the cluster:
pull off dask bezel
unplug headlight, 4x4/rear hatch/fog/rear wiper switches
trans in 1st gear and steering wheel tilted all the way down to remove the dash bezel
4 7mm screws to remove the cluster
clear housing unclips
push on the pins of the gauge motors to seperate the gauge face from the back
use a fork to pry off fuel gauge needle
2 T9 screws to remove motor
replace motor
I would fill the truck all the way up with fuel and then stick the needle back on about a 1/8" past F with the gauge plugged in the truck.
Then clip the clear housing back on and put the dash back together.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
your gonna worry about the charging voltage too.
---------- Post added at 10:16 AM ---------- Previous post was at 10:14 AM ----------
the gauge should be the same for swapping.
Phantom240
Phantom240
Wait, what about charging voltage? It settles back at 14v a couple seconds after starting.
Phantom240
Phantom240
That was very cold. Physically at about 52 degrees, hadn't been started since a couple days prior.
Phantom240
Phantom240
I'll run it a bit today after work, take it around the neighborhood a few times now that I have a plate and insurance for it, and I'll report back my findings. Also, I'm gonna put my multimeter on the battery to see how far off the gauge might be.
Phantom240
Phantom240
Still a little bit high, but this was after about a ten minute venture.
Coolwhip69el
