Fuel Injector failure or Fuel Injector Circuit failure?
Suburban2024
It looks Fuel Injector failure is sort of popular on 2023 Tahoe. From what I read here, GM tends to replace the failed injectors with new ones to fix the issue. But, is it a injector failure or actually injector circuit/wiring failure? The latter may be related to PCM or some other electrical causes. It seems P0207 is a popular faulty code on this issue. But it is hard to explain why it happens most frequently on cylinder 7 or maybe 6. There is no way for GM factory to install bad injectors onto specific cylinder 7 or 6 purposefully. If anyone has other faulty codes like P0201, P0202 or P0203, would you please take your valuable time to post your issues and discuss?
