fuel line broke by rubbing on the body
bde269
all over right now cold south dakota
I started smelling some fuel a few days ago and had a little time before I had to head to work and found that I had a line rubbing on the body i cut some rubber hose and put it on the line then fired her up to confirm my leak so sad my burb will be down a few days till im off trying to find a oem line is like pulling teeth going to try a compression fitting first then put my rubber hose on them so that doesn't happen again i told the boss (aka my wife) if i ever pull the motor im smashing that seam lol like B.B. King says if i didn't have bad luck id have no luck at all
bde269
bde269
lol yes my wife gets on me all the time lol. got a few compression fittings and banged it out then put some rubber hose on them so nothing will rub then ill find some new oem lines and route them clean.
Njoppy
