Fuel Line Disconnects, Fuel Pump, '99 Tahoe
h_d_ryder
Is a disconnect tool required when re-connecting the fuel flex lines to the plastic male lines of Fuel Pump Module? Can the flex lines with these connections just be pushed on to the F/P Module without using the tool? Also, is it best to use any assembly lube while installing the fuel line connections? Thanks for any help on this.
tahoesuperman
