Fuel Pump Trims
Going to look at a Tahoe in a few days with an intermittent starting problem. It's an '07 with the LMG.
What should long and short term trims for the fuel pump look like?
Mine are 1.2 or 1.5, can't remember.
For those of you with Torque Pro or Tech-2s, can you fellas check your key on and start pressures and post your trims please?
Mine keys on around 58 psi and always runs at 43.5, it's a 5.3 LC9.
@Doubeleive @gooffeyguy @SnowDrifter @kbuskill @iamdub Who am I forgetting?
kbuskill
NE. FL.
I know mine runs 43ish PSI while running. Never looked at it before starting.
I wouldn't think fuel trims would have much effect on starting.
You have any specifics of the "intermittent starting" problem? Slow cranking? Cranks fine but excessively long before firing up?
mine usually primes to 65 then drops to 43-45 after starting
BG1988
slow cranking could be the MAF sensor as well
common
sounds like my problem hahaha
dross99_si
SE Florida
common
Slow crank as in the speed the starter is turning?
Or slow crank as in the starter is turning at normal speed but the engine takes a while to fire up?
my2013
