Full Size Spare (275/70/18) ?
Jeff_
Scottsdale, AZ & N. Idaho
Hey guys hoping to get some insight here.
I know the factory spare is a 17" wheel with a tire that matches the factory size 18" tire (265/65/18).
Being that I have larger than factory tires (275/70/18) I'm curious if I can put a full size spare under the car.
I'm due for a new set of K02's before winter as my current set has 55k miles on them.
But my thought was if I could find a 18" spare wheel I could put the best old tire from my current set on it and mount it up under where the factory 17" spare is.
Because as it stands right now, if I have a blow out or even a flat, I don't have a matching size spare.
Anyone done this? Or anyone know where I can find a spare 18" wheel that'll fit like the 17" does?
Thanks
Jeff_
Jeff_
If I have to stick with a 17" tire, I'll have to buy one. But the closest match in a 17" to my 18" is a 285/70/17 which is 1.5% smaller in diameter than the 275/70/18.
So that means when driving it will be off by 8 revolutions per mile.
Not sure if that's enough difference to make a difference, and hurt the differential.
Jeff_
Jeff_
Sparksalot
Bastrop County, Texas
Good to know that fits!
Is it an 18" spare wheel you found, or a matching factory wheel or matching your aftermarket wheel?
Was looking for the crappy black stamped steel one. Like this factory 17".
Matching aftermarket wheel. I do 5 tire rotations to keep all of them at similar wear. I also have tpms in each one.
RST Dana
OH
As long as the diameter is near the factory tires you should be fine. I have a 22 inch wheel with the same tire as the originals in my 2020 spare location.
K2 Kaiju
The Depths
255/80/17 is much closer in diameter (0.3% smaller) and will not hang down as much (probably lighter and cheaper as well). Now that you mention this, I need to upsize my spare as well...
Jeff_
Jeff_
That’s actually not a bad idea either now that you’ve pointed that out. And I agree that it definitely won’t hang as low and will be lighter..
Appreciate the input.
