FYI Fumoto Oil Drain Valve
St. Louis
I've had an EZ-Oil Drain Valve on my Denali for about 2 years, no problems.
It's basically the same thing as a Fumoto, but chrome and uses an o-ring instead of a gasket. You can also get different hose ends that attach to it. I use a 90* one.
https://ezoildrainvalve.com/index.html
08grey
I've got some stainless one made by a veteran with a ball bearing for a stop i forget which brand it is but its nice. You just screw in the end with the hose attached and it drains.
Sent from my SM-G973U1 using Tapatalk
08grey
Its called a valvomax
the_tool_man
Upstate South Carolina
I put a Fumoto valve on my Yukon a while back. I've used it for three oil changes. It does take a long time to drain. But it's nice not having to use any tools for it. So I just go do something else while it drains.
BeenChevy
Minnesota
Which model Fumoto did you go with? F137n?
Always making a mess pulling the plug on this truck. Such a squirter. The 4x8 cardboard and 2 drain pans still sends ejecta on the wheels, arms, face..
BeenChevy
Minnesota
Glad to hear it. Model F137n appears to be the right one. Picked up some 3/8 tubing to go along with it. Just have to turn the truck upside down like usual and install it so oil doesn't spill.
Bagherra
Va Beach, VA
When i first got my '16 Denali, i installed a magnetic drain plug cuz i like to try to get most of the fuzz out....but i think i'm go with this....
so F107N or F137N is what i need?
BeenChevy
Minnesota
F137N supersedes F107N. It features a larger internal orifice which allows for a faster oil flow
marktorres4242
