Garage mistake - SOLVED
Denalidude10
Saskatchewan, Canada
Ok tire just changed my transmission cooler line and overfilled my transmission fluid now it shifting really hard and slipping hardcore and overrevving and sounding messed up the fluid is turning brown are they liable for the repair cost of a new transmission cannot afford to get a new transmission right now it’s been like 4 days using it like this should it be parked and will they fix this without charge
PPV_2018
U.S.A.
Shops are not liable if they do the requested work correctly and something goes wrong after … however … Shops are *definitley* liable for faulty or incorrectly performed work. The problem for you as a consumer will be… burden of proof.
Even if you could prove they made a mistake and they are liable doesn’t necessarily put then on the hook to drop you a fresh n crisp new trans in there. They may be required to only remedy the situation to make it to the condition it was before the work was performed.. so so many factors could go into this as you are asking a “legal” question and “legal” matters vary so broadly from state to state
Have you contacted the shop … you say it’s been 4 days.. every second that tics before you bring up the issue lessens the likelihood they will “help” you.
Denalidude10
Denalidude10
This was Wednesday it is now Sunday waiting for the shop to open Monday my kids have sports every weekend and we use this vehicle daily for their sports
Denalidude10
Denalidude10
I am posting this because my wife is stubborn as hell and won’t stop using her Yukon told her she can use my diesel truck but she hates using it and will probably use it till it blows the transmission
PPV_2018
U.S.A.
That’s all fine & well, but if it was on Wednesday, and the problem has persited since you picked it up, that’s 2 work days that have passed plus Saturday that they may or may not have worked. You can say well my kids this and my job that, but that is only going to help you in the “man i feel for you” department from other people …
.. from the shop’s perspective that argument will help you exactly zero. Contact the shop immediately (ie: first thing Monday a.m.!!) and see if you can work it out. Every minute that passes the shop has more of a case to say “wasn’t me” ..
Fwiw I’m only telling you this in *your* own best interest.. not the shops.. good luck
Denalidude10
Denalidude10
Think it’s on its last leg damn beast the abs brake light just came on the emergency brake light and the traction control light all showed up recently and the speedometer is bouncing omg never ending repairs on the Yukon anybody else have my problems on thier Yukon Denali XL with 6.2 LS 3???
wjburken
Eastern Iowa
I’m a little slow. Can you break down your post into at least a few sentences so it’s easier to follow for someone that’s a little slow like me?
Who changed the transmission cooler? You or the shop?
Who determined that it was overfilled? You or the shop?
Have you actually contacted the shop about this in the 4 days of it running poorly?
The shop can’t fix a problem they know nothing about. By continuing to drive it with these problems is not a good decision as they can simply say that you knew there was a problem and continued to drive it and exacerbated the issues so it’s your fault for some of the damages. I get needing a vehicle, but life simply sucks sometimes and you need to get things taken care of despite the inconvenience it may cause. This is like saying you got a flat tire after someone installed it but you needed to drive it and now the rim is ruined so they should have to pay for the rim as well. You have a responsibility to minimize possible damage as soon as you notice the problem or you will likely be liable for covering the repairs out of your own pocket.
If you are getting all the other warning lights, it may be worth while to check your cable connections on your battery, alternator, and ground locations as low voltage conditions can cause issues like these as well.
GMT800 SUV/Trucks
This post gives me a headache. How do you know it is overfilled and when did you know it? Don't care if she wants to drive it or not, park it till you get with the shop and please do a better job of explaining to them than you did here.
Denalidude10
Denalidude10
Ok ok tire changed my cooler line for me was still slipping when shifting after I picked it up so I checked the fluid level it was way over the fill line by like 2”-3” and the fluid is now brown and bubbly looking and smells burnt
Venator
