Gas Capacity
Stbentoak
I think its pretty sad that we have to live with a 24 gal tank on such a large road trip SUV. Even with the Duramax you are only looking at 500-550 mile range safely...
28 min would have been better....
Fless
Super Moderator
Elev 5,280
When you get old (speaking from experience) you'll end up stopping more often anyway. Pee breaks. Might as well gas up and get another cup 'o java. ;)
wjburken
Eastern Iowa
Truth! I used to have a 400 mile bladder and backside, but now, not so much.:oops:
C
Campingfamco
So has anyone experienced this on the new 21 Yukons or do most of yours fill up 22-23 regularly?
C
Campingfamco
So I’m still seeing the issue of not being able to get anymore than 20 gallons in per tank. Can someone confirm if they’ve been able to put more than 21 or 22 gallons of gas into their tank? Either I have a problem with my gas tank or GM advertised falsely by stating their is a 24 gallon gas tank, when in reality it’s something closer to 21. 3 to 4 gallons of unusable fuel seems very strange to me and I’ve never had this happen with any of my other vehicles across brands. Generally it’s within .5 to 1 gallon of capacity when you run it down low.
exp500
Go another 100 miles then fill up! Or not.
When I bought the Denali I didn’t buy it thinking I’d be getting great gas mileage. What I didn’t think about was the 24 gallon fuel tank. originally I thought if I got 15 MPG on average and say used 23 gallons of gas I’d have a range of 345 miles. Well the other day I ran it down to where the tank showed no gas on the gauge, which is really hard to tell on the display, and then the low fuel light came on. Typically this means you have 30 miles left.
I drove for about 25 miles in the same driving conditions and when I filled up, it only took 21 gallons. That was after filling it up, waiting 1 minute, then slowly trying to top it off. It was 20.5 gallons before that.
I’m curious if anyone else has experienced this. I find it hard to believe three gallons of gas is in the fuel lines.
Thoughts?
The system is calibrated to have the light come on when there's still 4-5 gallons or so on board. I do not know what the calibrations are for yours yet but this little chart is from mine and may give you an idea to work from:
Roscoe2352
