GEN X TRIMS Billet Grille
Dakota8
My wife just got a 2015 Yukon before Thanksgiving and I have been eager to add some accessories after reading through this forum, you guys know a lot of stuff. I ordered a GENXTRIMS Billet Grille and it came in the mail last night. I was happy with the construction as it is welded aluminum. Here is the link http://www.sleekautoaccessories.com...ushed-overlay-by-genx-trims?variant=752670249
For installation you bolt on the 4 separate pieces overtop the factory grill with a bracket that is on the inside of the factory grill. I am unable to get my hand behind the factory grille to put on the brackets so I figured I would take the grille off and install the 4 pieces and then out the grille back on. One person who reviewed this item on the website mentioned doing this.
First I removed the plastic cover overtop the front of the engine compartment. I then removed the 4 screws that hold the top of the factory grill on which I circled in Yellow in the picture. However I can't figure out how to remove the grille. Along the edges where I circled in red is a molded lip that latches onto metal of the vehicle. I can’t figure out how to get this loose. Would anyone with experience please give me a tip or tell me how to do it? Much appreciated. Thanks
Dakota8
Dakota8
Closeup of problem area
This pin is giving me the problem. It goes through the grille lip. Does anyone know how to take this pin out? Is there a certain tool I need? Any help would be appreciated.
Dakota8
Dakota8
Installed
I was unable to remove the grille or bumper. I did find some instructions online to remove the bumper with attached grille but I was unsuccessful. I was however able to pry the top of the grill back enough from the engine compartment to allow my wife to fit her hand behind and put the nut and lock washer on the backside of the grille. I am very happy with the look.
Dakota8
Dakota8
Front
mohammad alrjoob
Saudi arabia
In fact this pin you need to take it out from bottom. but after you have the whole bumper, by nose player, you return the for edges inside & then, it will get out, or you need to cuts it & have plastic pin
Nextruss
