Getting a tune, E-Fan settings question
sparks
Tampa, FL
I've been working with a local tuner to come up with a tune that will suit me and my driving best. We are down to a few of the smaller details, and one is the E-Fan pin activations and related settings. From what he says based on the options he has in the tuning software, we have the option for - no fans, 2 fans, aux fans, and an activation temprature. I currently have the BB harness with 2 ecu pins (33 green and 42 blue) that i was going to convert to a single 42 blue + ac compressor , but i read somewhere that pin 33 can be activated by a tuner as well. What settings are you guys using? What would be the optimal configuration? One big thing i would like is for the fans to NOT run on high just because the AC is running.
Suggestions, Comments, Recommendations????
sparks
sparks
Tampa, FL
ok so tune is done, fans are installed. we activated both pins, low speed is set to come on at 195, high at 205, speed shutoff is set at 45mph, and higs fans are set to trigger on ac recirc. the only issue we seem to have is that high speed fans arent triggering when ac is on (cant get it hot enough to trigger based on temp.) i had planned on setting up a 4th relay as a speed shutoff for both high and low fans, but i want to be sure the higs will trigger as they should. anyone have any suggestions of what to check in the tuning settings for the high speed fans? maybe even an optimal settings list?
dangerman4203
