getting rid of the roll pan?
BigDaddy13440
Rome, NY
Keep the pan. Fill in the frenched plate in the gate.
Is your pan steel? easy enough to fab up a recessed plate mount, tuck it low into the pan.
A
AtomicHoe094
Atomichoe094
cleveland, OH
you think that would make it look better? that might change my mind. maybe my heads just fawked from reading the license plate everyday at a tilt lol.
bowtiefreak
No Quarter
Near Philly
What about a Hid-a-hitch? I saw...years ago a hitch that will mount behind a roll pan and come out directly behind the license plate. The plate would fold done on a spring loaded set up for when the ball is installed.
Doing this may be an option
BigDaddy13440
Rome, NY
That is RIDICULOUSLY easy to do! I did one on my S-10 Blazer I used to have.
I took my plate off the rear, taped over where the plate would go with masking tape, then put the plate back on. Doing it this way, I was able to trace the outline of the plate on the tape, and not on the painted surface of the roll pan.
I carefully measured where the receiver hitch would be located, then cut (2) 4" holes side by side from the center, and cut the "V" from the top and bottom. I ended up with an oval 4" high by 8" wide.
Then, I scrounged around in the junkyards, finally found a flip-down license plate holder from an early-80's Cutlass Supreme (any car with the gas filler behind the plate would do). I mounted the bracket upside-down, covering the hole in the rollpan. Bolted the license plate to the bracket, worked flawlessly. Whenever I needed to use the hitch, I'd flip up the plate, and the oval hole would allow me to slip the pin in without having to crawl underneath the truck.
I also had the wiring harness attached to the hitch mount with a bungee cord - completely stealth.
96ProCompTahoe
IN
i like the idea of moving the plate back to the roll pan and using the hidden hitch.3rd gen camaro's use the flip plate as well with the hatch key behind it. (but you should know that, you have a T/A correct?)
A
AtomicHoe094
Atomichoe094
cleveland, OH
4th gen.. brother has the older TA (80)
but maybe ill see what i can work out as far as moving the plate. but idk im still leaning to the bumper again.
RepublicanRebel
