thefrey
- Joined
- Feb 3, 2025
- Posts
- 81
- Reaction score
- 54
I also swapped the motor mount while I had the pan out (and I’m glad I did) because of all the room. And the motor mount in there quit a long time ago
Amazing. I can't thank you enough for all of the help and info you've given me. I really appreciate it. I know what I need to do now and now I just need to do it lolI wouldn't worry about the Melling solenoid..... It's the actuator that screws into the end of the camshaft and controls valve timing, definitely stick with OEM for that. The solenoid is easy to get to if you have an issue, you're not pulling the cover again to deal with it.
No problem, that's what the forum is for. But not only saves you time working out the little details like that one bolt with a 10 mm box end wrench.... It will answer questions for a lot of people in the future that scroll through the subject matter for years.Amazing. I can't thank you enough for all of the help and info you've given me. I really appreciate it. I know what I need to do now and now I just need to do it lol
The L94 came with a HV pump from the factory. I used the Melling 365HV on my 2012 and my oil pressure has been great.So you'd say the Melling solenoid would be good to use?
I also am realistically not going to delete the AFM, so I think a HV pump will be a good thing to add to prolong the engine.
Oh interesting. Then would a Melling HV still be superior? I'm assuming it will still give me more oil pressure considering the original pump is probably somewhat wornThe L94 came with a HV pump from the factory. I used the Melling 365HV on my 2012 and my oil pressure has been great.
It's the one that Summit recommended to me at the time. I don't know if it's superior, but I know that it works very well in the L94. After my initial cam swap, I had to go back in and replace the pump because the factory pump wasn't keeping the pressure high enough - similar to your situation - even though I had replaced the o-ring with the same red one as you initially.Oh interesting. Then would a Melling HV still be superior? I'm assuming it will still give me more oil pressure considering the original pump is probably somewhat worn
Gotcha. I'll look into it. Did you need to drop your pan when you installed it or were you able to do it just through the front cover?It's the one that Summit recommended to me at the time. I don't know if it's superior, but I know that it works very well in the L94. After my initial cam swap, I had to go back in and replace the pump because the factory pump wasn't keeping the pressure high enough - similar to your situation - even though I had replaced the o-ring with the same red one as you initially.
Had to drop the pan, unfortunately.Gotcha. I'll look into it. Did you need to drop your pan when you installed it or were you able to do it just through the front cover?
