GMC Grill emblem put back together
rlvaldez
I am finally gonna take my grill emblem off my 04 Yukon to paint black, but do i need to do anything with the left over manufacturer adhesive, i have not seen in any threads that anyone has, and if i do how do i remove it? Thanks.
JochenWoern
Sacramento, CA
I have an '04 Yukon and did exactly what you are going to do. I just cleaned the emblem real good prior to painting, used my fingers and some rubbing alcohol which worked just fine.
Never reapplied any adhesive and just clipped the emblem back in the grill after painting. Never had a problem and it stays put.
Hope this helps.
R
rlvaldez
I should have been a little more specific looking back at my post. I am talking about the adhesive that is under the red GMC letters that hold it onto the emblem.
MABX13
Do you need to use a heat gun to take it off or you can pry it out?
JochenWoern
Sacramento, CA
Why would you want to take the letters out? Tape/mask the chrome parts and start spraying.
---------- Post added at 04:40 PM ---------- Previous post was at 04:35 PM ----------
It should unbolt
The emblem is held by some tabs into the grill, there are no screws. I never took the letters out of the emblem frame, so I am only assuming that the letters are glued in.
Yukongk
NY
I Plasti-dipped mine. Sprayed a few coats on and peeled off the plastidip on the chrome. Looks perfect. On my 2001, I just had to press in a few tabs that hold it in place.
