Good Deal Spotters' Thread
2000 Chevrolet Tahoe Z71 4X4 6,100 orig mi, absolutely NEW , pristine cond
Vehicle is 100% original including the tires. They do have slight dry rot cracks due to there age but the thread is like new. I didn't want to replace the original tires as it adds to its authenticity.
(Definitely extremely clean, but its got rust underneath, and all that rubber should probably be replaced... I'm AMAZED, THAT its up to US $18,700.00, with 16hrs left, 23 bids, and Reserve not met... WOW... )
eBay item number: 292935285291
https://www.ebay.com/itm/292935285291?_trksid=p11021.c100851.m5053&_trkparms=aid=222007&algo=SIM.MBE&ao=1&asc=20170803121420&meid=8fff127053aa474aae148493db9087e4&pid=100851&rk=4&rkt=4&mehot=pp&b=1&sd=223367877051&itm=292935285291&ul_noapp=true
Jersey 2018 inspection sticker.
adriver
I know this isn't anything too similar, but this is definitely a nice project for someone.. (54, 5 window, manual shift, AZ 71K mile driver.)
1954 GMC 100 truck 1/2 ton 5 window runs trades ? Drive it home - $5000 (PHX Chino valley)
1954 GMC truck 1/2 ton 5 window straight 6 manual shift
Clean AZ title Arizona truck has Vin tag matching Numbers
Original engine 71 k stick shift cluch good lights work
Has heater works 5000 $ obo trades welcome cbr Jeep Wrangler Harley Chevy Silverado Short bed Travel Trailer show contact info cheapest one in Az with title notarized ready to go show contact info Drive it home
(most posts get 1 picture, some times they are nice enough for 2 pics, this survivor deserves 3).
https://phoenix.craigslist.org/nph/cto/d/phoenix-1954-gmc-100-truck-1-2-ton-5/6807510628.html
$4800
https://phoenix.craigslist.org/nph/cto/d/phoenix-1954-gmc-100-truck-1-2-ton-5/6810324250.html
adriver
1982 GMC sierra 3500 Dually Price Reduced!!! - $800 (Temecula, CA) transmission: manual?
Truck for parts, ran about a year ago, then the squirrels got to the wires. Will sell with attachment for hauling 5th wheel. Will consider trades, let me know what you have. Asking 800 obo. text for more info and pics. i will not answer calls show contact info Need gone now!! leaving state in a month!
1994 2d Yukon 4wd MANUAL TRANSMISSION San Antonio. $6500
https://sanantonio.craigslist.org/cto/d/san-antonio-gmc/6814195375.html
(seen this posted in the past, looks clean, not sure how firm they are).
adriver
adriver
JUST IN CASE ANYONE IS LOOKING, OR ANYONE WANTS TO SEE SOMETHING BEAUTIFUL.. (not supposed to be a rainbow). I'm not saying that's not a great vehicle, but what I mean is;
THIS... IS HOW YOU SELL A VEHICLE!!!!
This was an ENTUSIAST'S VEHICLE..
99 2Dr,
1999 Tahoe 2 Door Sport LS 4WD
NEW:
Transmission by AAmco about 120,000 miles
Rear End by Chevrolet Dealer about 120,000 miles
New Fuel Pump
New Gas Lines Front to back (all)
New AC - Compressor, hoses, dryer, evaporator and pressure switch
Tune up, double platinum Plugs, new wires
New Distributor, New cap & Rotor
Brakes, Front, Back, master cylinders, one front Caliper (passenger) and some break lines
Re Built Alternator – intermittent bearing squeak
All new Front end, Upper & Lower Ball joints, Idler arm, Pitman Arm, Both Wheel hub bearing assembly’s
New Left & right Front CV axles
2 New front shocks KYB MonoMax 565062
New Power steering pump (not Re-built) with new hoses. High and low-pressure
New Window motors (2)
New Catalytic converter & 4 New o2 sensors
New Muffler & Tail Pipe
New Mass Air Flow Sensor
Reconditioned Heads, valve Job, Valve stems
Lifters all 16
New Intake gasket, Valve cover gaskets, Head gaskets
Spider Fuel injectors replaced with the upgraded Multiport injectors.
New Water pump
New Radiator, along with a new Lower Radiator hose
New Starter
New Belt tensioner
New Serpentine belt
New Crank shaft position sensor
Rear tires good about 30,000 miles on them (passenger side has a slow leak,)
2 new Front Tires.
New Front left & right ABS wheel sensors
New idle air control valve
New PC Valve & hose
New Ignition Module
New timing Chain
All maintenance records since new + Factory manuals
Engine runs very quiet and smooth.
Passed inspection in November 2018, no Check engine light.
Here is a list of the known issues:
Needs a front-end alignment
Battery 8 years old – still works
Needs a 4WD transfer case – It works but it will start to make noise after engaging it for about a half mile. This truck does not need the 4WD for snow. It is a 5,000 pound vehicle - I only use the 4WD if it hits ice. I use it for short periods of time. Then I go back to 2WD.
Rides OK, it is not a new car, it creaks when you hit bumps. typical of a 20 year old vehicle. A lot of surface rust on the under carriage. Frame looks solid.
Has been a very reliable vehicle for me. I have owned it for 8 years.
Here is a YouTube video: https://youtu.be/DQCbUijxqE4
Email me with any questions – Contact me if you want to take a test drive.
Please note FREE Shipping does not mean that I will ship it to you at no cost. This is a pick up only car. I will help your carrier load the vehicle - YOU PAY FOR SHIPPING
Good Luck Bidding
  • PREFERRED EQUIPMENT GROUP 3
    • Power Door Locks
    • Keyless Entry
    • Power Driver Seat
  • BLACK RUNNING BOARDS
    • Running Boards/Side Steps
  • 4-SPEED ELECTRONICALLY-CONTROLLED AUTOMATIC TRANSMISSION W/OD
    • 4-Speed A/T
    • A/T
  • RECLINING HIGH-BACK BUCKET SEATS
    • Bucket Seats
  • ETR AM/FM STEREO W/CASSETTE, COMPACT DISC, AUTO TONE CONTROL
    • AM/FM Stereo
    • Cassette
    • CD Player
  • LT DECOR
    • Leather Seats
  • 5.7L (350) SFI V8 (Vortec) ENGINE
    • 8 Cylinder Engine
    • Gasoline Fuel
  • SOLID PAINT
  • CUSTOM LEATHER SEAT TRIM
    • Leather Seats
  • REMOTE KEYLESS ENTRY
    • Power Door Locks
    • Keyless Entry
https://www.ebay.com/itm/233126717792?ul_noapp=true
Not affiliated, but I would love to see this get a bunch of followers to help them sell (I'm watching it). It might one hurt one member with price, but it will help everyone else with resale value.
BourbonNcigars
^ Wondering if that guy would have benefited from reading the recent thread about how much you put into your ride before saying enough is enough. Good ad, though, that's for sure.
99 2Dr,
NEW:
New Fuel Pump
Lifters all 16
New Water pump
New Starter
New Belt tensioner
New Serpentine belt
2 new Front Tires.
New PC Valve & hose
New Ignition Module
New timing Chain
Good Luck Bidding
    • Power Door Locks
    • Keyless Entry
    • Power Driver Seat
    • 4-Speed A/T
    • A/T
    • Bucket Seats
    • AM/FM Stereo
    • Cassette
    • CD Player
  • LT DECOR
    • Leather Seats
    • 8 Cylinder Engine
    • Gasoline Fuel
  • SOLID PAINT
    • Leather Seats
    • Power Door Locks
    • Keyless Entry
Damn, that's near me.
adriver
PRICE DROP TO $3900
https://phoenix.craigslist.org/wvl/cto/d/sun-city-1972-chevy-factory-shortbox/6815233210.html
1972 Chevy Real Shortbox on AWD Escalade frame Badass Project LS 6.0 - $4500
https://phoenix.craigslist.org/wvl/cto/d/sun-city-1972-chevy-real-shortbox-on/6811160356.html
Super cool project, we just don't have time to do it right now and making some space in the yard so testing the waters. Have a truck that started with a 72 chevy cheyenne cab with all the factory holes for headliner, cargo lamp, and uncut dash. Got the rest of the body from a actual short box, not a cut down box, solid factory GM bed sides. Then the truck has been mocked up on a 2002 escalade frame that is complete rolling All wheel drive chassis setup for 6.0 from factory but use any LS that is virtually same wheelbase as a factory short bed frame from 72. Now you have a badass AWD 72 with 4 wheel disc brakes already. Selling the complete rolling Body shell for $4,500 cash. Its a complete custom put together truck so it will need to be brought down to DMV and have a AZ assigned vin, basically making a hot rod. I do have LS motors available for different prices. also have a buildable 4L70E from the escalade, no transfer cases though. Let me know. its a complete project, I even have a 72 long bed frame that i will throw in with the purchase so you have all the mounts to get the body mounted to this frame, only need to cut the front ends off the escalade frame now so you can get the front bumper back where it should be sitting close to grille and fenders. text or call 612 29six 92 3 six thanks for looking and god bless.
PRICE DROP $4500 OBO.
https://phoenix.craigslist.org/nph/cto/d/phoenix-1954-gmc-100-truck-1-2-ton-5/6815391089.html
BKraft
