Got some 285/50/r22 NITTO recons. Any recommendations on a good psi setting?
Tusz
Curious if anyone here has found a good psi they run there’s at for a comfortable ride and even tire wear 2023 yukon. Any input would be helpful. Thanks
KMeloney
BTW, the manual recommends the stock 22" tires be inflated to 36 psi. Don't know why the recommendation for your tires would be any different.
d_hawk
Short answer -
P275/50r22 - 2162 lbs @ 36 psi (factory)
P305/45r22 - 2212 lbs @ 32 psi
LT285/50r22 - 2165 lbs @ 46 psi
33x12.5r22LT - 2160 lbs @ 60 psi
Long answer -
I have run 285/50r22 toyo AT3’s for over 40k miles on my suburban at 46 psi with no issues.
Snefferz
