Got the dreaded P0455 code... again..,
Steve Waddington
Burbank, CA
So I have this 20.00 scan tool that reads and clears codes. The last time I got this code, two weeks ago, I replaced the gas cap and cleared the code, and thought that was it. Last week it came on again. I tightened the gas cap, cleared the code... and it’s on again as of last night. So, it ain’t the gas cap ! Lol.
There are SO MANY other things it could possibly be! But before I start replacing each part one by one...
Is there a relatively inexpensive scan tool that will pin-point what the exact problem is ? P0455 is such a generic code!
most likely either the canister is plugged or one of the solenoids has failed or is failing, the front solenoid runs about $33, the rear about $50, canister is more expensive around $150
mine recently turned out to be the front solenoid. usually people just shotgun it and do all 3 because the cost of a diagnostic and labor and 1 part is almost the same if you just purchased the 3 parts and do it yourself. I would start with the rear solenoid and unplug it and see if any little round pellets come out of the hoses if you have loose pellets then do all 3 parts and blow out the lines with air while everything is all disconnected, if no pellets then you may get away with just doing a rear or front solenoid. I have a tech2 and tried to do a evap test but it turned out to be kind of a pain because it has to have just the right conditions (key off/on just right, cold temperature and rpm's 1800-2200 for the entire test) after several tries I just said screw it.
Erickk120
Yup, from the threads of that code it ends up being one of those 3 parts most of the time if the lines are fine. I shotgunned mine and did all 3 parts with AC delco ones, and its been over a year with no codes. 150ish for the canister, and like 30 and 15 for each of the solenoids
MCAT069
Texas
Check Amazon. Got all three items for like 70 bucks shipped; the canister was open boxed.
I keep getting the same damn code. Replaced the rear solenoid, then the gas cap and now I just ordered the front one at the intake manifold which happens to be a supercharger now and the one there has a part number off an 08. I'm not sure if Whipple supplied a different part when I installed the blower but I ordered the one that's there now.
willinnashville
Nashville
I had this problem a couple years ago and it ended up being the front solenoid. I replaced the canister and gas cap which didn't fix anything, and was really hoping it wasn't going to be the one on top of the gas tank. I ended up getting lucky it was the front.
donjetman
Eric, I recently got the check engine light(P0455 code) on my 07 6.2 Yukon Denali. The previous owner had recently changed the ACDelco 23481275 GM Original Equipment Vapor Canister Vent Valve($35 amazon) but the code came back, so I replaced the gas cap w/ACDelco# GT350 ($19 amazon) and the vapor cannister purge valve, located on top of the driver side fwd valve cover, w/ACDelco# 214-1680 ($19 amazon), so far so good.
Erickk120
Yeah, seems to be a common problem, some people don't mind the CEL on but it makes me go nuts when I see it on in any vehicle I've owned. My uncle has driven his 2001 since new and he has been living with CEL since 2008 after he replaced his gas pump and cracked one of the EVAP lines that runs around the gas tank, madman never bothered to change it.
Well the problem with that {besides the obvious one that it’s annoying) is there’s no way to know when another problem pops up and also throws a code. You’d never know unless you check codes every few days to make sure nothing new has come up.
Levi0320
