Got this error today(service tire monitor system)
nytahoe
"Tha Butcha"
new york
u can re set them ur self set the e break, turn the key to run, hold the lock and unlock on the key fab.the dash will say reset tires. driver side front tire let air out till the horn beeps the pass front same thing pass rear and last the driver rear and the horn will beep and thats it
crazycrew
Vacherie, LA
^^. That's how I did mine. I don't think it matters which tire you do as long as the horn beeps. Not positive though.
J
JBeezy
Sounds easy enough. Just read somewhere that the '07 and '08 sensors are different. I guess I can try when I get home to see if it works
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
bingo. ALso you need to do this too when you rotate otherwise it will read sensors as if they were in the original position
Administrator
:waytogo: I need to save these steps away somewhere for when I need them :)
J
JBeezy
This is my first experience with a newer Yukon. My wife sent me that pic and I wasn't sure what to think. I was beginning to think the sweet deal($400) I got on the wheels was too good to be true. Thanks a million for clearing this up.
04 beast
i had the same problem
all you need to do is take the old valve stems off your stock rims or go down to chevy and get new ones thats it
Shadfrmdabull
