Greasing the front wheel hubs.. (With pics)
jcevans7
Friendswood, TX
Someone else should do this and reply back how well it worked. Still seems fishy.
Sent from my SM-N910T using Tapatalk
chevyrider
What kind of grease should be used for this type of application?
Sent from my SM-N920P using Tapatalk
afpj
Will that interfere with the ABS sensor working? sounds like grease will not allow the sensor to "see" the rings?
J
Jdeshler
Alabama
Lol, dude this isn't a conspiracy theory.. If you don't believe it don't do it.
J
Jdeshler
Alabama
No, it doesn't effect the sensor because it doesn't sense through sight or infrared.. I can't technically describe how it works but I'm pretty sure it is magnetic
TheAutumnWind
its an electromagnet. The faster the frequency of the magnetic pulses the faster the tire is spinning. Wont be effected by grease. I'd use chassis grease... the same stuff you pack wheel bearings with.
retiredsparky
Ford super duty owners have been doing this for years on their front "unserviceable" hubs using lithium grease. Multiple write-ups on the various sites. The trick is not pumping so much in that it blows past the seal and gets all over the brake rotors.
One advantage of using the ABS port is that while you are pumping in the grease you can check for too much pressure, since there is no zerk fitting.
J
Jdeshler
Alabama
I have had my 7.3 for 6 years.. I had to replace the hubs when I bought it, you are correct.
TheAutumnWind
excellent. Ill pick up some lithium grease for this next time I have the wheels off.
Reyes1987
