Green OBS Tahoes
yukon95
Franktown, Colorado
I think that push that i needed haha! I want to do a 6 Inch rough country and maybe a body lift. but I haven't seen any pictures of a truck with that set up yet and I know that the body lift can sometimes look a little off. What lift do you have on your's it looks great?
*Well I Have been doing my reshearch around the forum and now I see that I am talking to the Lift guru. Would you mind if I pm you some quesitions about the lifting process on your 2 door?
96ProCompTahoe
IN
body lift on the OBS trucks shows a TON of frame. but x50 on lifting it!!
if you are running 9" lift, porbably in the 37's range you will want 4.88 gears. (running 35's with 4.88's)
AtomicHoe094
Atomichoe094
cleveland, OH
rather have too much gear then not enough esp lifted.
Just go the lowered way then you wont rip the shit out of your seats when you slide down that big truck ;)
yukon95
Franktown, Colorado
where do I shop for gears? I am going to put some racing seats in so they will have new upholstery so it will give it time to where down hah. Plus when you lower it it doesn't like going off-roading as much. I want to go out to do a lot of camping. Plus I allways wanted to lift my baby! If it can fit in the garage It isnt tall enough! or you have a one bad garage! But I think I may start by doing the gears. Then I will do the suspension lift and rock my 33's for awhile until I have the cash for the tires. That is what seems to be the most expensive part of whole set up. I want to put some 37 by 13.5 swampers on
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Heres James B's Tahoe.. Very clean and simple. Probably one of the fastest tahoes out there..
Very smart guy with alllott of knowledge
---------- Post added at 10:52 PM ---------- Previous post was at 10:45 PM ----------
edit some more.. one of James B doing a wheelie..
383 whippled :drool:
Atomic, more specs on the hot wheeler. Pleeeeaasssse!
Almo7annad
