Pilot
- Joined
- Dec 26, 2017
- Posts
- 329
- Reaction score
- 733
First off, I want to mention that I'm a total rookie and have no idea what I'm doing.
I recently had my Tahoe regeared from 3.73 to 4.56. Since then the speedo has been off. I finally decided to take the time today to flash the ECU with my Superchips Dashpaq+ to fix it. I haven't used the Dashpaq in a few years so I guess I forgot the process. I was surprised when well over an hour had gone by and the flash still had not completed. Then, suddenly, the screen on the Dashpaq goes black. I waited another 10 minutes or so and then concluded that it must be done. So I turned the ignition off (it was in the "on" position with engine not running) and then tried to start the truck. It did not start. Instead, crazy lights flashing on the dash and a disturbing buzzing/crackling sound coming from the steering column area.
Now the Dashpaq no longer recognizes the Tahoe. It just restarts over and over again when I plug it in and turn the ignition on. Tahoe will not turn over and all electronics are acting really funky (windows won't move, security warning tone sounds randomly, interior dome lights do light up but really dim....)
Since the Dashpaq had been sitting on the shelf for a few years, I brought it inside and attempted to update the software on the Dashpaq itself. It failed several times and gave crazy error messages instructing me to call Superchips tech support, but it's Saturday and they only operate on weekdays, so I kept retrying and eventually got the Dashpaq+ fully updated. I also unplugged the battery cable on the Tahoe while I watched the entire UT/Alabama game. When I came back out, reconnect the battery and the Dashpaq+ and tried starting the Tahoe, I got the clicking noise when turning the key, following by wacky flashing lights. After that, attempting to start the Tahoe does nothing at all.
SO. First of all, any insight at all is greatly appreciated. But I also have a more specific question; what are the chances that I can correct this with an HP Tuner? I was thinking about getting one anyway.. an MPVI3 is 399 and then 2 credits for licensing will be 98, so 497 total. I new ACDelco ECU at Rockauto is only 97, minus the core charge. Then add on some extra to pay to have the new ECU programmed I assume..\
What do you think? How can I determine if my ECU is fried? Should I go ahead and get an HP Tuner or order a new ECU?
