Has anybody found a decent portable compressor/inflator?
Eman85
If you're a scrounger find a junk vehicle like my 08 Envoy that has an onboard compressor for the air ride. Factory it comes with a long hose and is made to be able to pump up tires. Adapt it and mount it on your Tahoe.
Mean_Green
Mean_Green
I've been considering on board air.
Not big on carrying a compressor and a battery, so looking at 12V plug in units.
I have a bunch of Ridgid stuff, never looked at there compressor which turns out it is "hybrid" uses there 18v battery or can be plugged into 12v
also has a set it and forget it option (automatic shutoff), can be used as a "duster" also. not a fan of the lcd screen though
model: R87044
amazon review
Hoesgottaeat2
Western NY
I've had this Milwaukee M12 inflator for about 3 years now. Set the pressure and walk away to get something else done. It shuts off automatically at the set pressure. The lithium battery stays full when stored for months on end if necessary. I'd buy the larger battery for it if you plan on doing only truck tires.
The battery it comes with...
The battery I recommend getting(2x the run time)...
Trey Hardy
Eastern North Carolina
How durable are the hoses and valves on the ones mentioned? The el cheapo Harbor Freight and Tractor Supply type ones have a problem there. Won't clamp on and hold, hoses degrade, crack and leak, etc.
I don’t know about the hose on mine I think it’s rubber with a braided cover over it but it does screw onto the valve stem I do like that part
Rednim
