hate this crap
Tbruz
Windham NH
I replaced the radiator on my 1997 4 door without removing the fan or fan clutch.
Tbruz
Gzes
the drifting 2dr
Wichita tx
Yea no need to take off the clutch fan. I replaced mine easy no problem with all there
---------- Post added at 08:05 PM ---------- Previous post was at 08:04 PM ----------
In total it was an hour job even with a ****** up line because my dad accidentilla cut it because he didnt see we had adapters...
Donnie Yukonie
Donnie Yukonie
Yates Caretaker
you guys just took off the shroud? i found it much easier to take off both
foreverfalcon40
Just remove the fan shroud to uncover the bolts. With the right tools it is very easy! I guess if you want to overkill in space remove the clutch fan but not necessary and not worth the cursing and effort to break it free.
Monstar_est87
City of Angeles
Step 1.Drain radiator, Step 2. Remove the shroud, step 3. Take of clutch fan, Step 4. remove radiator and replace it with a 3500 4 core radiator, Step 5. bolt Mark 8 fan 2 ur shroud, Step 6. bolt everything down refill radiator with coolant and U'll be so cool every1 will call u culo... :)
Tricky
Illinois
Okay guys, now here is the million $ ?, can you replace the lower radiator hose with out removing clutch? Since I'm changing the 12 year old radiator might as well do both hoses, and should I change out clamps?
New radiator came yesterday like promised and doing job first thing after church.
Sent from my iPhone 4s using Tapatalk.
Tricky
Illinois
Well it's done, and didn't have to remove fan.
_Dylan_
STAY FROSTY
3500 radiator, is that bolt in to a 1500?
daddy g
