Hd front help .
Steven17
Hey I'm trying to put a 2002 silverado hd hood grill and top bumper pad on my 2003 tahoe does anyone know if I have to do any adjustments or cutting or will everything slap on ? Thanks in advance.
osiris94ej
Casper Wyoming
You will have to lower the bumper brackets on the frame horns a couple inches to fit right.
Sent from my SM-N920V using Tapatalk
Aaron_L
Arlington, TX
It's the actual frame horn itself that has to be moved. They need to be cut off and welded back on lower. I moved mine 1 1/4" because I wanted a tight bumper gap. There are also some brackets that go from the frame to the corners of the bumper that have to be modified as well. Also there is a lip on the bottom of the core support that needs a little trimming.
Also here's a tip: you'll either have to shorten/buy shorter bolts for the top of the bumper, or drill a hole in the top of the frame for the bolt to pass through. Since the horns are moved the top bolts are now too long and will contact the frame.
steezy5oh
