Head gasket sealer
TEXCHEVY
Italy
Hi all, has anyone tried "Blue Devil head Gasket sealer - Pour n go - ?
Does it work?
thanks
TEXCHEVY
TEXCHEVY
Italy
I have probably a small leak from the gasket of the head.
Scottydoggs
NJ
i used it on my old 3800 that ate small amounts of coolant. it sealed up what ever was the issue.
i later blew that engine up and pulled the heads and saw no gasket failure. not sure what was leaking, but it had to be the a crack in the block.
if you do a coolant flush you'll need more blue devil. its not like its sealed forever, mine started to eat coolant after i changed 1/2 the coolant for a rad change, had to re do the blue devil to stop it again.
also saw not blockages of the coolant ports in the block or the heads, so it wont build up crap inside the engine as far as i can tell.
TEXCHEVY
TEXCHEVY
Italy
I don't know what to do or think:(.........
last week happened:
1- It went down the engine oil pressure, after "red light" "check engine oil pressure"
2- changed oil and filter (PF61 ACDELCO)
3- I found refrigerant "very little" in oil filter :(......
4- After the oil change everything looks ok, the pump pressure exceeds the 275 kpa again...
5- instead of 5w30 I put 10w40 high mileage "Valvoline" , I also added coolant
6- driving for 300 km the car, the temperature has always been 85\90 C°, also in the traffic .
7- smoke from muffler only in the mornings when it is cold
8- I checked the coolant level , there's a "finger" to reach the full sign........
9- I could have air in the radiator?
TEXCHEVY
TEXCHEVY
Italy
no coolant in oil that I had changed, only in the filter
Scottydoggs
NJ
if its cold in the morning all cars look like they are smoking but its just steam as the exhaust warms up and condensates and steams off.
if you leave it parked and let it warm up for a little bit you'll see a small puddle under the muffler from a pin hole thats there to let the water out.
you dont have a rad cap, we have a tank, theres a cold and hot line, the coolant will raise and lower in the tank as the engine comes up to operating temps. so id check it cold, fill to the cold line, drive it normal, then check it the next morning when its cold, if its still at the cold line all is well.
TEXCHEVY
TEXCHEVY
Italy
thanks Scottydoggs I will do this check
Chubbs
There is available for purchase online or at the auto parts store a product for detecting the presence of exhaust in the coolant, aka "head gasket failure" or engine block/cylinder head structural failure. Inexpensive and informative. Add purified or mineral-free water to raise the "cold fill" coolant level to the operating specs. Examine the level at least twice daily, once before the engine is first started and again several hours after the final engine shut off for the day. Inspect the fill level of the tank and also the bottom of cylinder heads and the ground for evidence of leakage. If this evidence is found or the cold fill gradually lowers without visual evidence of leakage, the combustion gas test can be performed and preparations made for service & replacement.
You haven't noticed the presence of displaced fluids on the ground underneath your truck? Have you experienced overheat episodes or fluctuation of operating temperature? Do you have access to diagnostic tools like OBD device which plugs into the socket and displays ECM info?
I've never used blue devil but I can vouch for "K-Seal"
K-Seal held off a faulty head gasket I had for over a year but like Scotty, needed a second application when I changed the coolant. If sealers are used continuously the risk of blockage in various passages becomes a threat but 1 or 2 doses is fine while you save your pennies and weigh the options. Just be certain that you properly diagnose the issue. More often than not, head gasket & structural failures occur due to ongoing overheating from faulty radiator, fan clutch, etc. On the other hand, GM did manufacture a line of faulty cylinder heads with evidence of porosity that is found on specific make/model which you will easily find via Google search. Let us know if your vehicle fits the category of bad batch cyl heads and your findings on the coolant level this week. Don't wait until it gets super hot out before repairing this.
Best time to look visually for leaks is 30-min to 1 hour after the engine is turned off. Slide underneath and look with LED flashlight, hood closed for liquids running down hoses and the engine, especially the back where transmission mates and heater hoses connect to bulkhead.
My main conclusion here, properly diagnose the issue before using any additives or sealers, OK? You don't want to add something like a radiator sealer if there is no evidence of coolant loss, be it internal or external. And then if it's external, proper removal & replacement may be the way to go. And even then, other cooling-related parts could be cause for concern and exacerbating the coolant loss or overheating conditions. Also available for purchase at harbor freight or even rental from big chain auto stores is the radiator pressure tool. It will lose pressure if the cylinder head is porous. It may or may not hold pressure depending on the damage of an actual head gasket. There are principles behind all of these diagnostics but you have to know what you are doing or further damage will result from improper DIY hacks, especially when it comes to the cooling loop. So be careful & thorough, keep the board posted and take the time to ask questions and perform research.
TEXCHEVY
TEXCHEVY
Italy
I will do these tests and write the result here. for the moment, thank you so much
shadowid60
