head lights
X
XxBIGxTEXxX
ok.. thanks sunlit.. im placing an order right now to see if i can get them in time... i might have more questions once i get them on how to install them properly once i get them... on the alternator, once i put the led lights, the gauge battery reader drop down from the half mark to like almost the quarter mark.. and the alt is new.. is that normal?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Not normal at all. Either something is wrong with your electrical system or if you removed your gauge cluster it did not re-seat on the connector properly. take it out make sure contacts are clean and not badly scratched and re-install.
X
XxBIGxTEXxX
it was out before way before i took out my cluster... So ether fuse, cable, or connection is bad...
SunlitComet
OBS Jedi-Do Good
Remember the volt gauge reads the voltage that powers you cluster. Use your imagination and zen shall show you the way.
Instrument Cluster
Electrical Diagrams
Notes
62392267
Gauges & I/panel Illumination
Notes
62392268
Warning Lamps & Speedometer
custom97
NW Houston
I installed some 8k 35w HID's on my 2dr Hoe and it is day and nite difference. I haven't installed the relay harness yet but I will. Having some flickering and initial start up problems on the driver side headlamp. Overall, worth the money. I would suggest TYC Elegante over Anzo. Just my .02
cofferson
