Headlight harness suggestion/problem
EnzoDenali
I recently changed my head light bulbs to led after the change my driver's side headlight stopped working tried swapping lights didn't work and so I thought maybe the female end of the harness but still nothing. Can anyone help help, should I just get a whole new harness or headlight ?
Before firing the parts cannon, do some initial diagnostics (or report on what initial diagnostics you have already performed).
Did you check the fuses for the head lights?
Do you get 12 volts at the light socket when the light switch is turned on?
When you tried swapping lights, di you swap new LED for new LED, or did you swap old incandescent for new LED?
Thustlelovemuscle
