I say your switch is toast. Change it before you loose everything on it.
Forgot to mention if you have cruise the price might be $40 higher.
Instructions for tilt:
http://www.sunlitcomet.com/pdf/automotive/tahoe/98-99/1999-multiswitch-tilt-steering.pdf
and not tilt:
Dont forget Arir bag disarm:
1. Turn the steering wheel so that the vehicle's wheels are pointing straight ahead.
2. Turn OFF the ignition.
3. Remove the key from the ignition switch.
Important: With the AIR BAG Fuse removed and the ignition switch in the RUN position, The AIR BAG warning lamp illuminates. This is normal operation, and does not indicate an SIR system malfunction.
4. Remove the AIR BAG Fuse from the Instrument Panel (IP) fuse block.
5. Remove the Connector Position Assurance (CPA) (1) from the driver yellow 2-way connector located at the base of the steering column.
6. Disconnect the driver yellow 2-way connector (2) located at the base of the steering column.
7. Remove the Connector Position Assurance (CPA) (2) from the passenger yellow 2-way connector located near the base of the steering column.
8. Disconnect the passenger yellow 2-way connector (1) located near the base of the steering column.
And re-arm:
1. Remove the key from the ignition switch.
2. Connect the passenger yellow 2-way connector (1) located near the base of the steering column.
3. Install the Connector Position Assurance (CPA) (2) to the passenger yellow 2-way connector located near the base of the steering column.
4. Connect the driver yellow 2-way connector (2) located at the base of the steering column.
5. Install the Connector Position Assurance (CPA) (1) to the driver yellow 2-way connector located at the base of the steering column.
6. Install the AIR BAG Fuse to the Instrument Panel (IP) fuse block.
7. Staying well away from the air bags, turn ON the ignition.
7.1. The AIR BAG warning lamp will flash 7 times.
7.2. The AIR BAG warning lamp will then turn OFF.
8. Perform the SIR Diagnostic System Check if the AIR BAG warning lamp does not operate as described. Refer to SIR Diagnostic System Check
