doncaruana
- Joined
- Apr 11, 2016
- Posts
- 192
- Reaction score
- 72
So my low beam burned out and I went to pull the headlight assembly. I started working on the two 5mm rods that stick up and...they just spin. One spins loosely, the other turns but is still tight.
When I first started, both had to do a little 'pop' to start. So I'm guessing the nut they drive into way down there is broken.
Meaning I have to pull the whole grille likely at this point to change the bulb, right?
But if those rods are stuck, will I be able to get the lights off with the grille out? And, more importantly, will I be able to put the lights back in, after I replace the bulb? I wont be able to use the rods again, but would it still hold? Or should I buy a new headlight assembly and pop it in there?
