Headlights Always ON
arcticcajun
arcticcajun
Interior Alaska
So I have also found that when I attempt to lower the illumination via the slider on the left side of the steering wheel, it does not control the instrument cluster, nor the infotainment screen. There are no settings for the screen brightness like on my 15 Silverado. The more I dig into this thing, the more weird it gets.
Check the operation of the sun sensor, if it thinks it is dark out you won't have any manual control other than to turn the lights off manually, one way to check operation of the sun sensor is to see if the puddle lights illuminate in daytime if the OEM fob is used to unlock the vehicle and approach lighting is enabled
arcticcajun
arcticcajun
Interior Alaska
I will check that out!
Well Worn Chevy
