I haven't heard of anything on the new trucks but you could always bring your concern to the dealer and ask them to check the alignment and check the output with a lux meter, which they should have but not 100% certain.Does anyone else on here feel like their headlights are dim when driving at night???
it seems as if the LED is drowned out and not projecting. If anyone has had this concern, how did you resolve?
Relatively easy to figure out, reach down and manually activate the headlights...Does the green headlight indicator go on on the dash.Could have the faulty headlight sensor issue that causes headlights to come on during the day, not sure if they are reversed and don't come on at night...meaning you're only seeing the lights the DRL's are providing. Worth investigating if you can see the reflections of the headlights vs. DRL's on the back of another car in the dark.
2015 here, What headlamps and fog lights did you get? I have halogens right now.I've installed the brightest headlamps I could find! Also, installed brightest fog lights as well and use them 100% of the time - aim them up a bit - it really works well. My vehicle - 2004 yukon xl
