Headrest dvd player hard wire.
Alextahoe
Lawrence, MA
I'm installing headrest monitors on my 2003 Yukon Denali and I don't want to run wires all the way to the hood fuse box, is there a hot fuse in the cabin fuse box that I can use? Can I tap into the electric seats wiring? Thanks...!
danniboi
If you have rear seat audio controls I would try there, remember to always throw in a fuse in between if your going to tap into an existing wire.
MassRCDude
Tacoma, Wa.
Yes......that will be enough. I installed headrest monitors in my 05 Denali and i just used the supplied fuses and tapped into one of the ignition wires under the dash.
DCT
If you have power seats, you can tap into power under each seat near the harness.
Helmetgurus
