heat in my 98 yukon
misspooh
connecticut
the heat in my truck blows out warm but not hot. new thermostat, new blower motor, heater core was replaced about five years ago. any ideas?
95TwinTT
Minnesota
Check the vacuum controlled coolant valve. Make sure it is operating free and opening all the way.
99Yuk
Northern Ontario, Canada
personally i'd remove that. i did and i get wicked heat now.
Hey, how did you do that?
That seems like a really good idea!
Might be one of those 'doh' moments as to why didn't I do this sooner!
Living five hours north of you it gets colder up here!!!!
We often joke that up here its so cold that we only have two months of bad skiing!
95TwinTT
Minnesota
I don't think the air con can over power the heater core in the cooling mode.
Like in the defrost mode when the air cond is on and the heater core easily makes hot air. The air con, dries the air and then the heater core heats it up.
It's that valve that varies the flow of hot antifreeze to the heater core. :)
a9lyphe
