Heated Seats
tna0066
Both of my heated seats stopped working at the same time. I checked my fuse, which is oddly the same as an ignition fuse...it was fine. Is there a relay or something i should be looking for? When i press the buttons on both drivers and passenger side, nothing happens, no lights or anything come on.
SnowBuck
If one seat pad is shorting out, it trips the relay, then neither works.
T
tna0066
So neither side works for heated seats, and the drivers power seat doesn't work either...passenger power seat works fine though
Justinj360
I have this same issue and I finally found the problem. If you open up the rear drivers side door and look under the drivers seat there's 2 connectors that are clipped into a metal bracket on the floor. There should be a little plastic cover over the connectors. When I unclip the large connector and move it around a little and try the power seat and heated seats it's like nothing was ever wrong with them. It always goes out shortly after they start working again though. I'm taking it to my mechanic as soon as I can for this. Hope this helps!
Justinj360
So I finally got that connector apart today. It wouldn't let go and now I know why! And evidently its called a "body harness connector"
