Heated seats
tooslowtahoe
What's the best way to wire in some heated seats for a truck that did not come factory.. Seats form a 00 tahoez71 to the same drivers plugs in but passenger doesn't
SunlitComet
OBS Jedi-Do Good
unknown at this time.
obtain the seats and related controls for dash and with the proper wiring and wiring methods use the diagram and build it up. but controls for your truck will likely have to be from a donor obs. not sure if a nbs truck control head can snug into an obs holes. no spares lying around here for me to see if it would fit the dash sorry.
tooslowtahoe
tooslowtahoe
Ok thanks, controls are in the seats it's an obs thought I typed that but I didn't. So would the same apply?
SunlitComet
OBS Jedi-Do Good
you just need two separate power feeds to the seats one is for switch control power on both seats the the other bigger one is the heater power feeds to the controllers.
tooslowtahoe
tooslowtahoe
Ok this is what I have coming from the seat 1 black wire 1 yellow 1 brown and 2 orange. I have 1 orange and 1 black coming from truck. So can both orange wires be connected to the one coming from the truck. And where or what can I run the yellow and brown wires. Thanks I'm a five year old when it comes to this stuff.
SunlitComet
OBS Jedi-Do Good
brown taps in to the convenience center for control power. orange for load power black is ground and yellow is part of the seat belt buckle switch on right seat. the yellow is not used on the left front seat i think.
tooslowtahoe
tooslowtahoe
Ok thanks for the info will give it a. Try
Jayhawkeye3
