Heater issue
B
BigShowJoe
Update on this - Issue is fixed. It was not the blend door or the actuator for it. I started with taking that off and it all functioned correctly. Ended up taking the lines off of the heater core and connecting a garden hose to the outlet (far right) side. Some gunk came out but it ran clear and smooth pretty quickly so I had my doubts that it was fixed but I tried and VOILA!! Super hot heat. Got up into the 140's. I guess the backflush dislodged something that was causing flow issues.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Great! If flush every 30k the gunk usually does not ever build up. Typically a flush will not fix a clog like that unless it is a loose clog, like what came out. Anyways, great!
kevinw
