Hi All,
Owner of a 2001 Tahoe LT 5.3L.
Having issues with rear A/C blowing warm to hot air > Already looking into replacing the blend actuator. Both of the rear seems to be malfunctioning.
ABS and E-Brake lights are randomly turning on. > This did not occur until after getting the brake calipers and brakes replaced.
I have a bird under my hood. At times I hear a loud high pitched sound. I had a body who is a mechanic look into it and we ended replacing all the pulleys, tension,idler, and eventually the water pump as well as replacing the serp belt and ac belt. Noise disappeared for a few months and then came back again. He made sure that all pulleys were properly aligned. Tried purchasing a Gator back belt but they seemed to have discontinued or I can't find one for the Tahoe. < Looking for a possible replacement belt to fix the noise or belt dressing, but cautious of the belt dressing as there have been reports of the belt actually dis-aligning after spraying or treating with belt dressing..Any ideas?
Any assistance would be appreciated.
Regards,
AC
Regards,
AC
