Hello all,
Here are some more pictures of the exterior as of this morning and some interior shots of it the day I got it. Bit of back story, My Dad's colleague's relative died a few months ago and his Tahoe was sitting under a tree outside of the once every 2 week drive his widow did. It was a Delivery truck for their small business in the construction sector. The exterior was beat from being under a tree for so long without being washed and the interior was probably just as beat. There has been some custom work done on it like Audio. Picked it up for cheap as no one in their family wanted it.
I did a wash on the outside and vacuum/carpet cleaned the inside so far. Drying out the interior as we speak and I'm going to see how it all turns out. Maybe i'll need to get something stronger than elbow grease and a shop vac. Will need to do a second exterior wash later as there is stuff in a lot of the creases a wash mitt and a regular hose couldn't get too. Some dings and scratches, but no rusting in the quarters or wheel wells and I don't see the clearcoat fading in any part.
Fluids getting swapped this week.
Some of the problems I've noticed so far, outside of cleaning.
1. Tailgate latch is broken, New on is on the way, tumbler and rods on the inside look to be all there so we are good once I get the handle.
2. AWD Service light is on. The 2x.AWD.4x Switch is broken. It is stuck in AWD mode. I'm hoping it is just the switch, could be the actuator since the 4x side still clicks, just does not swap. Hoping its not anything worse.
3. Power locks only semi work. The motors pull on all the locks, but on the drivers side it doesn't pull it all the way down like 90% of the time.
4. Driver side power window is broken.
3 and 4 might be a switch/electrical issue? Going to and fix as much as I can on my own. Hoping that the custom Audio (looks like they did it at home) didn't mess any of the electrical up in the doors.
No engine lights, Drives smooth, Brakes are strong, Its Auto and shifts smoothly. Going to work on this one bit by bit and try and pick up some new skills.
Thanks for reading.
