Hello from Yukon Canada
Moe007311
93 I had change water pump after I was done I plugged battery back then I seen hose I need adjust I had extension in my hand I touched the alternator with out noticing and the block then I heard it sparks twice then I said I hope I didn't burn out alternator then I started it started then it died out then I tried again it wouldn't start again only clicks with out turing then I changed coil and ignition module then it started with sound as its miss firing then I changed sparkwires then it started normal and idled for FEW moments with out miss firing then idle drops as its choking then it dies and keep doing it every try I make too start it again in same order / I changed my water temperature sensors 8 months ago and oil pressure sensor you think they burned too it was running perfect before I changed water pump what you think
YukonandtheHOE
YukonandtheHOE
Well, Generally speaking arcing off your alt won't hurt anything. Have you checked all your grounds? Have you made sure its not a fuel issue?
Is the base timing wire some how unplugged? Its located passenger side under the dash, its a one wire connector orange wire iirc. Check the fues's and connections under the cover on the passenger side fire wall. TBI's are pretty much just SuckBangBlow and reliable as hell.. check that stuff out and let me know.
Btw Grammar.. Learn it, love it, use it
DCmoe
