hello hello new here from nj
jroman
question about the switch that tells you if your in 2w or 4w drive. I have no lights on there. guy told me its all good. just put in neutral and hit button.
wondering if that's normal.
also on the ride home. I had some vibrations that would come and go. felt like in the rear.
truck has 130k on it. pretty clean less sagging headliner.
truck pulls to the left. guessing an alignment might fix this. need tires up front.
not sure what size I should put on. the same that's there or change size.
would it be ok to get alignment and then tires later on.?
this is not gonna be a daily driver. will use when needed. I purchased truck because I don't want to use my lowered chevy pick up during the winter. as well as getting something that I can put my two kids in.
I wanted a chevy I like the front end better then the Yukon front. but I thought that the kinda low miles was reason to buy truck.
thanks for any info.
z0lt3c
Central NJ
NJ winters are not nice to these vehicles... 130k miles can result in alot of wear and tear.
The 4WD switch itself can often fail, I would start by testing the switch but it's not normal to have no lights.
Vibrations could be alot of things, I would start by replacing the bad tires and having the wheels balanced and aligned. I've personally had good results getting alignments at Pepboys and I like their 3 or 12 month warranty option, I usually get 2 or 3 alignments for the price of one. I would stick with the same size tire unless you want to replace all 4.
I would definitely check out your hard brake lines, they all tend to rust out w/ the NJ road conditions.
xBoostx
