04YukonAWD
- Joined
- May 16, 2014
- Posts
- 61
- Reaction score
- 0
I have a 2003 Cadillac Escalade ESV that I'm having an A.C. Issue.
It has the typical Front A.C. Is warm Rear A.C. Is Cold probIem.
I have checked the freon level and it was in the good area. Both door climates work from cold to hot. The compressor works and engages.
I have replaced the A.C. Accumulator vacuumed the system and recharged it but still no cold air in the front. Blower works As Well.
The low side line going to the evaporator core gets cold. But the return line coming from the evap core does not along with the line coming from the accumulator to the compressor??!!
Does the evaporator core need to be replaced? Is the orfice tube the culprit?? I am at a lost here.
