mikez71
- Joined
- Mar 9, 2023
- Posts
- 1,626
- Reaction score
- 1,901
Possible if you did not clean them, that the oil could contaminate the pads.? (guessing here, but there must be a reason we are instructed to clean new rotors)
Might help to give your rotors a quick non-directional sanding (150-220 grit I think..)
and maybe blast your pads with brake cleaner and wipe clean..
Since you mention it happened last time...
I notice play in one of my rear calipers. I can move it maybe 1/16" or less. I think its the guide pins or bore being worn. I plan on new calipers with brackets soon. (~$85 a piece from rockauto)
In my case the rear pads were installed incorrectly (not by me, but I could see it happening if someone is rushing) It damaged one piston surface, and I wonder if being cocked put extra wear on the guide pins. (brake pad angled because a nub that was supposed to be on the outside, was installed on the inside which interfered with the piston)
