Ever since I got my yukon the dash cluster some times goes a little wacko. it started with just a security light coming on once in awhile and an airbag light coming on but now it's gotten worse. all at once my fuel gauge will go to empty my voltage gauge will go all the way down my temperature gauge will drop all the way down security light will come on seat belt light will come on battery light will come on. sometimes it goes back to normal right away other times its not till the next day that my dash cluster is normal. but not for long.
I have looked up this issue online and all I can find is 03+ Denalis and Cadillacs that have this issue and that are covered under warranty I have not found anything for an 02 yukon.
has anyone had this issue if so have you gotten it fixed, how much has it cost you, and what have you had to do to fix it
