help! cluster going crazy!
01ssreda4
Not to high jack, But my 04 Just went completely dead. No guages at all, no check engine light, No odometer, No ABS light. All at once. I've checked all the fuses, any help would be greatly appreciated. Thanks
Youtube video for that. Search for it:) Pretty easy fix too.
---------- Post added at 04:20 PM ---------- Previous post was at 04:17 PM ----------
also a symptom of a bad PCM
You spew more crap here then anyone else Ive seen! How can a bad PCM cause an entire cluster to go dead when IT DOESN'T CONTROL THE WHOLE CLUSTER????? What he described is a very common problem and has nothing to do with the PCM. :Nonono:
Drippin Wett
well. I youtubed as suggested. Took the cluster apart, soldered the conector pins, and BAM back to working, Thanks!!!!
01ssreda4
Booyaa boyiee. Hate it when I'm right! Glad you got it fixed buddy.
emfadz
