Help decode rpo'so on SPID
M123
M123
Viking
Sweden
Wow thanks that was a super great suggestion. :) :) Yes I will do that.
Thanks. :)
Antdogbmx
Now you got me curious. My truck has a Texas made sticker I think ,
M123
M123
Viking
Sweden
Thanks always nice to hear when someone appreciate a own car. :)
Your second post I don't really understand what you referring to? :)
Do you mean your SPID and where your car are built or is it related to you number plate and insurance?
Guess my poor English gives it away that I am not English-speaking. :D
M123
M123
Viking
Sweden
As mentioned here from the forum gods I do have the rpo code's ZW7 and G65.
Now my shocks are covered in undercoating so can't see what I have but doesn't this shocks looks like regular ones?
As my car are very stiff I have my bad feeling that someone down the lane have change out my suspension against something non stock.
Or what does the forum say? :)20200422_133216.jpg
You can really see the size difference. Much bigger.Resized_20171218_113928_63752626173856.jpeg
Here's the tag with part number from the original shock. Came from the rear of my 03 Tahoe. They're very expensive when bought new.
Fless
Super Moderator
Elev 5,280
Or what does the forum say? :)View attachment 245311
Your shocks do not appear to be the G65 (Nivomat, manual self-adjusting) shocks. Nivomats would have a much larger diameter. I suspect they've been changed, although typically changing them out to regular shocks would require a stiffer rear spring (like the Z71 springs); otherwise the suspension is squirrely. Perhaps the springs that may have been installed are too stiff?
M123
M123
Viking
Sweden
This forum rocks for real, it's alive and have serious knowledge. :)
Thanks guys @Tonyrodz and @Fless this was very helpful.
@Tonyrodz Yes I did see the G65 shock's did have sky high prices on them and are they worth it? Those pictures are amazingly good. :) :)
@Fless Yeah the car are to stiff, I did buy the car in the city south of here and the road where I did test drove it was silky smooth so didn't felt something odd.
But here at home the car doesn't feel right, the handling are super in the curves, but it doesn't eat up the bumps in the road, it's messed up for real. :)
How can I tell what springs are right or wrong for my setup?
Must I buy everything new so I know what I have?
Guessing the springs look alike but have different performance.
Now it did get to many questions in one post. :D
M123
M123
Viking
Sweden
The GM page didn't work, did send back broken links so I never did get a active account. Did try many times and zero luck.
Did read on the Internet people sending email to [email protected]
Did try it and fast response, they did send back right away a PDF with the Build sheet.
Super service! :) :) :)
Down below if someone are interested I have it.
Thanks for all the help and a warm welcoming here on the forum. :)
Vehicle Build:
Model: 2002 Tahoe ½ Ton 4WD
VIN: 1GNEK13T82Jxxxxxx
Build Date: 10/30/2001
Build Plant: J
Option Codes:
122 - GRAPHITE CUSTOM LEATHER
TRIM
12I - GRAPHITE INTERIOR TRIM
1SM - PREFERRED EQUIPMENT GROUP
1SM
6XK - COMP FRT LH COMPUTER SEL SUSP
74U - VICTORY RED
7XK - COMPONENT FRT RH COMPUTER SEL
A04 - TINTED WINDSHIELD
A31 - POWER SIDE WINDOWS
AG1 - 6-WAY POWER SEAT ADJ -
DRIVER
AG2 - 6-WAY POWER DRIVER & PASS SEATS
AJ1 - DEEP TINTED GLASS
AN3 - 6-WAY POWER HEATED BUCKET SEATS W/FRNT LEATHER
SEATING SURFACES & DRIVER MEMORY
AT5 - REAR CENTER FOLDING SEAT
AU8 - REMOTE ENTRY LOCK CONTROL
AX4 - EUROPEAN SEAT BELTS
AXP - MPV VIN IDENT POSITION
B30 - WHEELHOUSING & FLOOR
CARPETING
B39 - COLOR KEYED FLOOR MATS CARGO AREA CARPETED
B58 - COLOR-KEYED FLOOR MATS,
FRONT AND CENTER SEATS -
CARPETED
B71 - WHEEL OPENING FLARES
B85 - BRIGHT BODY SIDE MOLDINGS BAG - EXPORT PARTS PACKAGE
C25 - REAR WINDOW WASHER & WIPER
C36 - AUXILIARY HEATER
C49 - REAR WINDOW ELECTRIC
DEFOGGER
C5U - GVWR: 3084 KGS (6800 LBS)
C60 - AIR CONDITIONING WITH AIR
FILTRATION SYSTEM
C69 - AIR CONDITIONING-FRONT & REAR
CT1 - COUNTRY - BELGIUM
D07 - CUSTOM FRONT FLOOR CONSOLE
DF5 - INT R/V MIRROR, LIGHT
SENSITIVE W/OUTSIDE TEMP &
COMPASS
DH2 - ILLUMINATED MIRRORS ON VISORS
DK7 - INTERIOR CUSTOM ROOF
CONSOLE
DL8 - OSRV DUAL POWER HEATED MIRRORS
E2C - RAPID DELIVERY SYSTEM PROC
OPT
E52 - LIFTGATE/LIFTGLASS
EXP - EXPORT PROCESSING OPTION
FK2 - TORSION BAR SPRING ADJ
FK3 - TORSION BAR SPRING ADJ
G65 - LEVEL CONTROL MAN,SELF ADJUSTIN
G80 - LOCKING REAR DIFFERENTIAL
GT4 - 3.73 REAR AXLE RATIO
J81 - INDICATOR SWITCH, EXPORT JAN - ASSEMBLY PLANT-JANESVILLE,WIS.
JE1 - EUROPEAN BRAKE SYSTEM
JH5 - 4 WHEEL PWR DISC BRAKES,7200LBS
K34 - ELECTRONIC SPEED CONTROL
K47 - HIGH CAPACITY AIR CLEANER
K53 - ROBUST FUEL SYSTEM
KG8 - 130 AMP GENERATOR
KNP - H.D. TRANSMISSION COOLING
SYS
LM7 - VORTEC 5300 V8 SFI GAS ENGINE
M30 - 4-SPD AUTOMATIC
TRANSMISSION WITH TOW HAUL MODE
MAE - MARKETING AREA EUROPE PROCESSING OPTION
N12 - REAR EXIT EXHAUST SYSTEM
NP5 - LEATHER WRAPPED STEERING WHEEL
NP7 - EEC APPROVED STEERING
COLUMN
NP8 - AUTOTRAC ACTIVE TRANSFER CASE
NT3 - EEC OO EMISSION SYSTEM
NZZ - OFF-ROAD SKID PLATE PACKAGE
PF4 - 16 X 7 ALUMINUM WHEELS
QMJ - P265/70R16 BW TIRES
R7K - PROCESSING CODE
R9Z - POMS EXPEDITE-SOLD ORDERS
SLM - STOCK ORDERS SLT - EQUIP CHEV 'LT' SALES PKG
T2H - EXPORT EXTERIOR
ORNAMENTATION
T2J - EXPORT INTERIOR ORNAMENTATION
T62 - DAYTIME RUNNING LGT-DELETE
T79 - REAR FOG LAMP
T84 - RH RULE E MARK HEADLAMPS
T89 - EXPORT TAIL & STOP LAMPS
T96 - FRONT FOG LAMPS
T98 - STAMPING VEHICLE ID
TR2 - ENLARGED TURN SIGNAL LAMP
TR6 - MANUAL HEADLAMP LEVELING CNTRL.
UC2 - KILO SPEEDOMETER &
ODOMETER POSITIVE BIAS
UG2 - UNIVERSAL GARAGE DOOR OPEN, DEL
UL2 - EUROPEAN RADIO FREQUENCY
UQ3 - ENHANCED AUDIO SPEAKERS
UW3 - AM/FM STEREO RADIO
W/CASSETTE
UY7 - WIRING HARNESS TRUCK TRAILER
V17 - OCEAN FREIGHT CHARGES
V19 - MARINE INSUREANCE
V22 - DELUXE FRONT GRILLE
V54 - ROOF LUGGAGE CARRIER - PAINTED
V78 - DELETE VEHICLE STATEMENT
V92 - TRAILER PROVISIONS
VB3 - CHROME REAR STEP BUMPER
VC5 - EXPORT SHIPPING LABEL
VD1 - EUROPEAN OPTIONS PROVISION
VG3 - FRONT DELUXE CHROMED BUMPER
VJ3 - ECE LABEL,PLATE & VEH IDENT
VJ4 - CHILD SEAT WARNING LABEL
VP3 - NOISE CONTRL EUROPEAN
PROVISION
VPH - EXPORT VEHICLE PREPARATION
VR7 - SECOND RR TOW HOOK
VXS - COMPLETE VEHICLE LABEL
VZ2 - SPEEDOMETER CALIBRATION A
X88 - CHEVROLET NAME PLATE
XMJ - TIRE FRONT P265/70R16-111S BW YD3 - AXLE BASE EQUIP PROECESSING OPT
YD6 - BASE RR SPRING PROCESSING
OPT
YE9 - LS DECOR
YMJ - TIRE REAR P265/70R16-111S BW
ZM9 - COMFORT & SECURITY PKG INCLS: * CARPETED FLOOR MATS *
ELECTROCHROMIC OSRV MIRRORS * HOMELINK PROGRAMMABLE
TRANSMITTER
ZMJ - SPARE TIRE P265/70R16-111S BW
ZW7 - PREMIUM RIDE SUSPENSION
ZY1 - SOLID PAINT
joshdee123
