HELP!! Did a u-turn while in 4Hi on dry pavement, now no-more 4WD.
turbotalon1g
Did a slow speed u-turn and now none of the 4WD modes will work and I have service 4wd on the DIC.
Tried to disconnect the battery and cycled the key, but still no luck.
Any insight?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
What year/make/model?
Administrator
Why were you in 4wd on dry pavement? Doesn't sound good :(
T
turbotalon1g
Thank you for the help guys.
I just got the codes pulled and it showed 1 active code:
C0379 - Front Axle Circuit Malfunction.
It showed 2 other history codes in addition to the active code, they are:
C0306 - Motor A/B Circuit Malfunction
B0790 - Transfer Case Neutral Indicator Circuit
Oh, we did clear the codes and it instantly came back on when the vehicle was turned back on.
A quick google search, shows that either axle solenoid or the encoding motor, but my problems didn't just randomly happen I caused it with a U-turn or pissed it off enough and maybe it had an issue before.
Thanks again for the help.
T
turbotalon1g
Well I had a friend come by and help me out, we checked the front axle solenoid and figured it wiring, checked the
Switch and it was the fuse.
Thank you to everyone, I can't believe it was that simple.
T
turbotalon1g
hahaha, just trying to use the resources at hand my friend.
Now onto the next issues! and to find some stock wheels that aren't insanely priced!
Capeles
