HELP!! Engine Knock After Oil Change
A
autoworks856
ok, i started it up again, nd the noise is fading away more than it did a few days ago. its not as loud anymore, but still noticeable. and i also noticed it smoked a little bit, but stopped momentarily.
im going to put conventional valvoline 5W30 into it later and see if that makes any significant difference.
steamroller
The South
It might be a leaking anti-drainback valve in the filter since it's 4 wheel drive and the filter is installed on it's side. Basically it's letting the oil run back out of the filter after you shut it off, just a thought.
As far as oil I'm a big fan of Pennzoil Platinum, my oil was alot darker the 1st couple oil changes with it. When I pulled the intake manifold for intake gaskets it was spotless on the inside, looked like a low mileage engine when I had 160k on it
A
autoworks856
so jus cange the filter? i figured it was that, because i had used a fram filter at first, nd now i used a carquest filter from my job
KrautBurner
Bremerton, Wa
you can use SeaFoam in the oil prior to changing it,
it may help clear the oil ports (which may be clogged)
if you do,
go ahead and run the truck to full opperating temp for a few min.
then change the oil as usual.
good luck
steamroller
The South
It might be worth a shot to just swap the filter, I think the carquest are made by Wix though, they may be Purolator??? The Purolators have several smaller oval shaped holes in the top plate
Theres some pics in this thread over on bobistheoilguy of the Wix filters if youwanna compare....http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1231291&page=2
For what it's worth I use WIX filters or the AC Delco made by Wix, I usually have to dig around and open some boxes, because some of the latest AC filters are crap with the plastic E-core, same as the cheap STP oil filters
Another good read if your interested, though it may be dated info, you can usually tell what filter is what by the top plate and the drainback valve seal
http://minimopar.knizefamily.net/oilfilters/reference.html
AtomicHoe094
Atomichoe094
cleveland, OH
What do you mean plastic ecore?? hmm.. usually i never use fram or those cheap *****. My trucks oil pressure would go nuts with the fram filters, stepped it up to a mobil1 now its completely fine..
steamroller
The South
Read that last link I posted, it was done on filters for Mopars but there are good pics in there to distinguish who makes whos filters....Some of the Delco's are from the 'performance' line of Champ Labs, some are the E-core, and some are made by WIX..... They may be fine but I won't use em
E-core STP, SuperTech, etc. plastic center cage, felt like filter caps
A
autoworks856
im dropping a new motor in it, noise is still there.
would there be any problems dropping a motor from a 95 into my 98??
h0tr0d
Brenham, Tx.
The 98 is a Vortec motor and I think the 95 is still TBI. You'll definitely want to stick with the Vortec as that EFI is much better than the old TBI system.
Pull it out...throw it on a stand, flip it over, pull the oil pan and yank the crank out when you can. My money is on a spun crank bearing...which is cheaper to repair than to drop $1400 on a reman motor. You could have the whole thing back together in 8 hours worth of work and however long the machine shop takes to polish the journals on the crank and give you the new bearings.
Jacobamers
