Help! Lowered tahoe riding on bump stops
S
SaMoT
The bolt is almost turned all the way. I'll try installing the new stops when I get them, if that doesn't help I will probably end up going with either drop spindles or the new lower control arms. Thanks guys!!
I also plan on new sway bars, Panhard bar, rear upper and lower arms in the near future.
But first gotta fix the front that way I can install my wheels.
Aaron_L
Arlington, TX
In your pic you posted the bolts are backed out. When you turn them in it will raise the vehicle.
S
SaMoT
Will turn them all the way tomorrow in the morning and will check back. The keys were advertised as 3 inch.
S
SaMoT
I got the bolt on the key turned all the way now, this is how she sits. I took her out for a short test drive and the ride is way better than what it was not like stock but way better.
The jounce stops are still compressed in the arms just waiting on those to come in to install the new ones.
Thanks guy!!
macking
